Unhandled Exception c0000005 (Access Violation Reading 0x6000b0d) at address d1d1c271h
Product(s):AutoPLANT Modeler  CONNECT Edition
Version(s):10.00.XX.XX
Environment:Windows 7/8.1/10 (64 bit)
Area:Error, Logs, Messages, Crashes
Subarea:
Original Author:Abhijeet Shinde, Bentley Product Advantage Group
Some user may face “Unhandled Exception c0000005 (Access Violation Reading 0x6000b0d) at address d1d1c271h”  error when  tried to launch AutoPLANT Modeler Session.
This error generally occurs due to following reasons.
1.When user install Microsoft Access Database Engine before installation of AutoPLANT Modeler
Note: User can install the Microsoft Access Database Engine after  installation of AutoPLANT Modeler
2.Install multiple versions of Microsoft Office on the same machine.
This wiki article explains the steps to help resolve this issue.
Steps to Resolve
Case 1
If user has installed Microsoft Access Database Engine before installation of AutoPLANT Modeler
1.Unistall the Microsoft Access Database Engine
2.Unistall  AutoPLANT Modeler CONNECT Edition
3.Reinstall  AutoPLANT Modeler CONNECT Edition
4.Install Microsoft Access Database Engine
Case 2
If user has Install multiple version of Microsoft Office version
1.Uninstall the Microsoft Office
2.Uninstall AutoPLANT Modeler CONNECT Edition
communities.bentley.com/.../autoplant-modeler-connect-edition-update-1-installation-procedure
Still a Problem?
Comments or Corrections?
