How to do Silent installation of Bentley Raceway and Cable Management-CE
 Product(s):Bentley Raceway & Cable Management
 Version(s):CONNECT Edition (10.xx.00.xx)
 Environment:N/A
 Area:N/A
 Subarea:N/A
 Original Author:Aadarsh Tale
Silent-mode installation allows you to define an installation configuration and then use the configuration to install without any user interaction.
There are two ways to execute the silent installation:
  1. Create a Deployment Image.
  2. Directly use the Setup File.
Create a Deployment image which will act as a pre-configured offline installer. This method has the following benefits:
You need to configure the InstallDirectory & ConfigurationDirectory variable to control the installation and configuration directories at the desired location. In this method, there will be no possibility to control the features and the companion applications which means everything delivered with the package will be installed.
This article will cover all the important aspects of Silent Installation of Bentley Raceway and Cable Management CONNECT Edition.
  1. Download the installer for Bentley Raceway and Cable Management CONNECT Edition from the CONNECT Center. Refer to the below Wiki Link for steps on How to Download Bentley Raceway and Cable Management CONNECT Edition Installation Package.
communities.bentley.com/.../how-to-download-bentley-raceway-and-cable-management
The following steps are for the Silent Install by creating a Deployment Image:
  1. Once the Installer file is downloaded, Deployment Image needs to be created for Bentley Raceway and Cable Management CONNECT Edition. The steps to create deployment image can be followed from the below Wiki Link.
    communities.bentley.com/.../how-to-create-deployment-image-for-brcm-connect
  2. After the Deployment Image has been created, the Deployment Image folder needs to be copied / deployed on the Machine locally where Bentley Raceway and Cable Management CONNECT Edition needs to be installed Silently.
    Note: The Installation Path & Configuration Path Selected while creating Deployment Image will be default Path for Silent Installation unless specified during Silent Installation.
  3. Next the copied Deployment Image folder will contain the setup file for Bentley Raceway and Cable Management CONNECT Edition like " Setup_BRCMx64_10.05.00.54 ". Copy the Mapping Path as highlighted in the above image. After the Path is copied open Windows "Command Prompt" by searching in Windows Search.
  4. To Silent install with the Installation Path and Configuration path details selected while creating Deployment Image, you need to Paste the copied Path for the BRCM Setup as shown in the image below.
  5. Paste the Setup file name after the file location.
  6. Now add “-q -s -restart” in the command line and Press Enter to execute.
    -q(quiet) -s(silent): Quiet mode, no user interaction [wix bootsrapper command for silent installation without any user interaction].
     -nonrestart: Do not restart after the installation is complete.
The following steps are for Silent installation directly through Setup file:
  1. Paste the copied path for the BRCM Setup followed by the Setup file name as shown in the image below. This command will execute a silent installation at the default path using default settings.
  2. To Install Bentley Raceway and Cable Management CONNECT Edition at a Specific Installation Folder and Configuration Folder; you can use the below given variables to specify the locations as shown in the image.
    InstallDirectory: This is the directory into which the Bentley Raceway and Cable Management CONNECT Edition’s associated files will be installed. (all supporting .dll and other files).
    ConfigurationDirectory: This directory contains configuration files and sample workset.
communities.bentley.com/.../how-to-install-brcm-connect-edition
Still a Problem?
Comments or Corrections?
