Dark mode
- Matching MicroStation, OpenBuildings Designer now has a dark mode as well.
Level mapping utility
- Assign part & family to referenced elements from multiple formats based on their layer/level in the original product. This tool is accessible as a part of a technology preview.
Productivity Improvements
- IFC NURBS (bsplines) surfaces implementation
- We have continued to improve and expand the technology preview of NURB surfaces in IFC exports, giving greater control over , faceting, files sizes and visual presentation of complex geometry.
- IFC Export Improvements- ProStructures elements
- We have improved the fidelity of ProStructures geometry containing sub features such as cuts and voids when exported to IFC files.
- Representation symbology
- We have improved the fidelity of rendering materials when exported to IFC.
- Curtain Wall improvements
- A Curtainwall is now exported in such a way as its sub elements can be listed as a subtree to parent element in an Ifc file.
- IFC Relocation Tool
- For instances where referenced ifc files are incorrectly located and have to be manually repositioned on attachment, the new IFC relocation Key in command writes the current attached position to a new, duplicated IFC file. The new ifc file can then be attached with the new location being the default location.
Source in other languages
German
