| Area: | ProStructures Interoperability | ||
| Subarea: | Configuration |
I've created a new Workspace in the existing Configuration to house my custom Worksets. However, when attempting to use this new Workspace I am getting this "Configuration Audit Alert" message referring to ProStructures:
The audit alert is advising you that your new workspace does not include the new ProStructures content (and associated configuration variables) required in order to successfully run the application. Unlike creating a new Workset, the process of creating a new Workspace does not offer the option of selecting an existing Workspace to use as a template, so these required files are missing.
Assuming you already have a regional workspace installed, copy the folder ..\Configuration\Workspaces\Buildings_Examples\Standards \ProStructures\ to the equivalent location in your new workspace:
In your new workset.cfg file make sure there is an include statement so that the applicable dataset content is included as well. For example, if the US dataset were being used the line would look something like this:
% include $(_USTN_WORKSPACESROOT)/Building_Examples/WorkSets/BuildingTemplate_US.cfg
NOTE: Once your new workspace is properly configured and you are ready to create a new workset, you can use the configuration variable _USTN_TEMPLATEWORKSPACENAME to choose a delivered workspace name so that the workset templates drop-down list will be populated. Otherwise this list will be empty since the new workspace you've created has no existing worksets to choose from. Once that first workset is created it will act as the template for all new worksets created within your new workspace.
Also see: ProStructures "Configuration Audit Alert" message after opening Update 7 for the first time
New and modified files in OpenBuildings Designer Update 7 datasets
Source in other language
German
