| | Product(s): | OpenBuildings Energy Simulator | |
| | Version(s): | CONNECT Edition | |
| | Area: | General Information | |
This article explains how to print / plot a copy of your OpenBuildings Energy Simulator model.
Method
The following steps show how to print the currently selected view:
- Click onto the View you wish to print.
- Set up view as required - position the model and set Display Style - eg if you wish to plot the building plan then Wireframe:White Background may suit:
- Select File > Print:
- Here you can Print, Print Preview, and Print to PDF. Print Preview would be recommended firstly, to make sure all is set up as required, then select Print:
