| | Product(s): | OpenBuildings Energy Simulator | |
| | Version(s): | CONNECT Edition | |
| | Area: | Building Modelling | |
There are several different ways of creating your building in OpenBuildings Energy Simulator.
Method
- Standard Project - The standard method is to trace your rooms directly in the OpenBuildings Energy Simulator modeller. For this floor plans are imported (DGN/DXF/DWG) and then used to trace the 3D rooms. To do so select Standard Project when starting your project.
- Conceptual Project - this is a quick method of entering the basic building geometry manually. The software then creates a simple model which can be used for preliminary calculations.
- Hevacomp Model Import - Existing Hevacomp Design Database projects can be directly imported into OpenBuildings Energy Simulator (see here).
- GBXML Import - this can be achieved as shown here.
- Analytical Space Model import - existing BIM models can be imported into OpenBuildings Energy Simulator via the Analytical Space Model function (info here), located within OpenBuildings Designer:
