Product(s):
OpenBuildings Designer
Version(s):
CONNECT Edition
Area:
Platform Tools
Problem Description:
How to import Saved Views from one file into another file in OpenBuildings Designer?
Steps to Accomplish:
- Open the *.dgn file into which the Saved Views need to be imported.
- Choose Drawing Production > Create Views > Saved Views.
- In the Saved Views dialog click on the Import Saved View icon.
- Select the required file from which the Saved Views will be imported.
- From the Import Saved Views dialog select the required views and click the OK button.
- The selected views will be imported in the Saved Views dialog. Select any of the views, and using a right mouse click select Apply.
- Click on any blank space in the active view window and the selected Saved View will be applied to it.
