Applies To | |
Product(s): | OpenPlant Isometrics Manager CONNECT Edition |
Version(s): | 10.XX.XX.XX |
Environment: | Windows 10 (64 bit) |
Area: | Settings/Attributes |
Subarea: | |
Original Author: | Abhijit Bute, Bentley Product Advantage Group |
During isometric generation user has configured report.def to move pipe support form Shop session to Field session. However, the sequence of components in the field doesn't confirm their standard.
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
communities.bentley.com/.../how-to-show-support-components-under-field-or-shop-material-list-in-bom
communities.bentley.com/.../autoplant---openplant-isometrics-manager-connect-edition
