Specific Fan Power
 Version(s):CONNECT Edition
 Environment:N/A
 Area:Part L
 Subarea:N/A
Specific Fan Power for fan coils can be set up to emulate a central air system, or as a room unit.
Method
For Central air handling systems, the specific fan power - where known - should be specified under the System Adjustments tab on the HVAC System screen.
The specific fan power for individual fan coil units can be defined under Room Data > Night cooling and terminal units.
