| Product(s): | OpenBuildings Designer |
| Area: | Drawing views |
I am creating a pipe. I want to change the centerline of this pipe to match the newly created family and part. I use the ‘apply part’ tool to do this, but the new part and family don’t match the pipe. Changes are not visible. How to fix this issue?
One of the solutions is to check if the Ctr Ln Toggle option is enabled or disabled. If it is disabled, you won’t notice any changes in your drawing.
To check it:
1. Open Family/Part Editor
2. From the Parts View select “Centerline Symbology”
3. Check if the “Ctr Ln Toggle” is on
