Bentley Facilities Space Planner CONNECT Edition Update 4.1
What's New Highlights for Bentley Facilities Space Planner CONNECT Edition, Update 4.1 (v10.04.01.10)
  1. Supports MicroStation CONNECT Edition Update 17.2 (v10.17.02.61) + OpenBuildings Designer Update 10.1 (v10.10.01.151)
  2. Supports ProjectWise Design Integration Server (v10.00.03.299), ProjectWise Administrator (v10.00.03.434) unconstrained + (v10.00.03.299) with restrictions - see Wiki, ProjectWise Explorer Client Update 3.4 (v10.00.03.453) + (v10.00.03.434) and ProjectWise Explorer Client Update 3.2 (v10.00.03.299)
  3. Supports Windows Server 2019 with SQL Server 2019 and Windows Server 2016
  4. Supports Windows Server 2019 and Oracle 19c setup
  5. Update 4.1 addresses security issues
  6. ‘ProjectWise asset tagging’ - Deprecated feature/No support
    No option to install it with the regular installer. (If needs to be installed, then create a deployment image and install it through msi)
See also Bentley Facilities Space Planner Compatibility with ProjectWise, Microstation & OpenBuildings Designer
