Bentley Facilities Space Planner Compatibility with ProjectWise, Microstation & OpenBuildings Design
Product(s):Bentley Facilities Space Planner
Version(s):CONNECT Edition
Environment:N\A
Area:General
Subarea:ProjectWise, Microstation, OpenBuildings, Facilities Compatibility
ProjectWise, Microstation & OpenBuildings Designer CONNECT Edition Compatibility with Bentley Facilities Space Planner
Bentley Facilities Space Planner CE
ProjectWise CE10.04.01.1010.04.00.3510.03.00.2810.02.00.23 10.00.00.4710.00.00.45
10.00.03.453YesYesXXXX
10.00.03.434YesYesYesXXX
10.00.03.140XXXYesXX
10.00.03.49XXXYesYesX
10.00.02.265XXXYesXYes
Microstation CE
10.17.02.61YesXXXXX
10.17.01.62XYesXXXX
10.16.00.80XXYesXXX
10.11.00.36XXXYesXX
10.10.00.23XXXYesYesX
10.06.00.38XXXXXYes
OpenBuildings Designer CE
10.10.01.151YesXXXXX
10.10.00.199XYesXXXX
10.08.00.44XXYesXXX
10.04.00.38XXXYesXX
10.03.00.40XXXXYesX
10.02.00.35XXXXYesX
10.01.00.36XXXXXYes
See Also:
ProjectWise Compatibility Tool - Microsoft PowerBI compatibility matrix between ProjectWise and applications from Bentley, Autodesk, Adobe, Microsoft, etc..
ProjectWise Version Support Matrix - Click on Select a Publication in the ProjectWise area and scroll down to ProjectWise Version Support Matrix
