| Product(s): | OpenBuildings Designer | |
| Version(s): | CONNECT Edition | |
| Area: | Import/Export | |
Problem Description
How to import a google map location into OpenBuildings Designer?
Please go through the below steps through which you can easily import a google map location into your OpenBuildings Designer.
- In the Google Earth Pro application search for the required location.
- Select Add Placemark.
3. Place the marker and rename accordingly.
- Save the Marker in the desired location as *.kmz file
- In OpenBuildings go to Define Placement Monument and browse the Source.
- Select the *.kmz file created.
- Snap the base point
- Export to Google Earth (*.kml).
- The Model will get reflected in the Google Earth Pro.
10. In your OpenBuildings Designer, click on Capture Google Earth Image.
- Go to Geographic Coordinate System from Placement and select the marker.
- Wait for the map to get loaded.
- The map will be seen in your OpenBuildings Designer.
- In the View Attributes go to the Background Map, select the Type as per requirement.
Note:
Make sure that your User Account Control Settings is set to Never Notify
