| Version(s): | Connect Edition /V8i | ||
| Area: | Customization | ||
| Subarea: | N/A |
You are willing to improve the look of shadows in your display styles using solar lighting? Currently you areĀ having a buildingĀ like below.
Along with a view like below.
There is a setting in the lighting manager dialog that will drastically improve the look of shadows.
You will be ready with a improved solar lighting image.
You can further use the same dialog and set the solar lighting to match your site location, Date and time to get accurate solar lighting.
