| Environment: | CONNECT Edition | ||
| Area: | Print/Plot |
User was getting the following dialog asking if they want to Save the drawing now... when opening the IPLOT Dialog.
1.Exit any open Drawing.
2.Go to Control Panel - Add/Remove Programs
3.Highlight OpenBuildings Designer
4.Click Repair from the Toolbar above the product list.
Try plotting the file again.
