| Area: | ProStructures Interoperability |
How can I apply a chamfer to ProStructures elements?
Below is the workflow to apply a chamfer to ProStructures elements.
1. Place a ProStructures element in the model - in this example we will use a Plate that has dimensions of 200mm X 400 mm.
2. From the Structural tab choose Modify Steel Members > Element Modification from the Cut Structural Elements tool group:
See also: How to add the ProStructures modify tools to the Structural ribbon
