OpenPlant PID V8i (SELECTseries 10) Requirements
- Processor
- Memory
- Hard disk
- Input device
- Output device
- Video Graphics card
- Operating system
- Optional Integrations
Processor
- Intel ® or AMD ® processor 2.0 GHz or greater
Back to top of section
Memory
- 512 MB minimum, 2 GB recommended. More memory almost always improves performance, particularly when working with larger models.
Hard Disk
- 8 GB free disk space (which includes the 6.4 GB install footprint for a complete installation)
Input Device
- Any industry standard input device supported by Windows
Output Device
- Any industry standard output device supported by Windows
Video Graphic Card
- Graphics card supported by DirectX 9.0c. See the graphics card manufacturer for latest information on DirectX drivers. 256 MB of video RAM or higher is recommended. If insufficient video RAM or no graphics card supported by DirectX can be found, OpenPlant PID attempts to use software emulation. For optimal performance, graphics display color depth should be set to 24-bit or higher. When using a color depth setting of 16-bit, some inconsistencies will be noted.
Operating System
Please refer to BE Community site for Operating System requirements OPPID SS10 Compatibility
Please refer to BE Community site for DMS Platforms compatible versions OPPID SS10 Compatibility
Optional supported integrated software includes the following production versions. Later priority builds are also acceptable.
Prerequisites and Common Tools - below listed are the only supported versions
- AutoPLANT Modeler CONNECT Update 2 versions (10.02.00.48)
with ProjectWise CONNECT Edition Update 3.3 (10.00.03.334) - (Client) with CONNECT Edition Update 3.2 (10.00.03.280) (Server, Adiministrator)
- SS8 08.11.14.124 Refresh 3
with ProjectWise versions 10.00.03.167, 10.00.03.140 and 10.00.03.49
- SS8 Refresh 08.11.13.245 Refresh 2 installed on top of Refresh build 08.11.12.211
with ProjectWise versions 10.00.02.265 and 10.00.01.67
- SS8 08.11.13.129
with ProjectWise versions 10.00.01.67 and v8i SS4 08.11.11.590
- SS7 08.11.12.252 patch installed on top of Refresh build 08.11.12.227
with ProjectWise versions 10.00.00.20 and v8i SS4 08.11.11.590
- SS5 08.11.10.205 patch installed on top of Refresh build 08.11.10.182
with ProjectWise versions v8i SS4 08.11.11.590, 08.11.11.574, and 08.11.11.559
with ProjectWise versions 10.00.03.167, 10.00.03.140 and 10.00.03.49 AXSYS SS4 08.11.09.52
