| Area: | Import/Export | ||
| Subarea: | IFC |
How to export a DGN file to IFC using iTwin Technology?
Please go through the video below and follow the steps which will demonstrate how you can easily create an IFC file from any DGN file. The authoring DGN file can be from any Open product such as OpenPlant, MicroStation, OpenRoads, etc..
Click here to watch the video.
You can also check out this wiki to know more about the iTwin Technology.
