| Area: | Drawing Views | ||
| Subarea: | Family & Parts |
Problem description
How can I change the material of a specific element's assigned Part using the Family/Part Editor?
The workflow below will allow to change the material palette used by elements that are assigned a specific Part.
4. Once complete, click on the Save button and close the Family/Part Editor dialog.
