How to place/import a PAZ file in a DGN file?
 Version(s):CONNECT Edition
 Area:Import/Export
Some of our users have PAZ files they need to place in a DGN file, but not as a DatGroup enabled element. Is that possible?
There is a key-in to directly place a PAZ file into a DGN file: TFPACELL IMPORT
 After using the key-in a dialog will come up from where you can choose or select the PAZ file from any location,
After clicking on ‘Open’ that PAZ will be directly placed as a cell in the DGN file at global 0,0,0.
