| Product(s): | OpenBuildings Designer | |
| Version(s): | CONNECT Edition | |
| Area: | Architectural Design | |
Problem Description
How can I change the color of a Railing after placing it in my 3D model?
Please follow the below steps through which you can easily change the color of railings after placement.
- After placing the Railing, open the Family/Part Editor tool.
- After opening the Family/Part Editor tool, change the Parts View to “Rendering Properties”.
- In the Handrail row click on Render Material and there will be a list of materials that you can select as required for your railings.
- After selecting the proper render material click on the Commit Changes icon to save the changes.
- Finally, you can see that the color changed for the existing railing as well as if you place a new one.
