| Area: | ProjectWise Integration |
We sometimes see that at the time of using a ProjectWise Project with the current WorkSet, when clicking on the ‘Browse’ tab the ‘Associate Project to Workset’ page does not open,
This issue generally happens when a compatible CONNECTION Client version is not installed. To fix this issue you will need to install the proper CONNECTION Client version for your environment. After that when you click again on the Browse option the ‘Associate Project to Workset’ window should open,
