| Area: | Platform Tools |
Problem Description
How can we attach an image on the surface of an element in OpenBuildings Designer?
The simplest way to attach an image on the surface of the element is through the Material Editor tool. We have created a short video of the workflow showing the this process. Please go through the attached video below.
