| Product(s): | OpenBuildings Designer | |
| Version(s): | CONNECT Edition & V8i | |
| Area: | Architectural Design | |
| Subarea: | Roof Design | |
Problem Description
What is the best way to create Mansard roof in OpenBuildings Designer?
Steps to Resolve
Mansard Roofs can be created using Roof Builder tool.
Steps to be followed:
- In the ‘Architectural Design’ panel under Building Designer Tasks, select Roof Builder. The Roof Builder dialogue box appears.
- Choose “Gambrel Roof” among roof types.
- Modify the “Upper Slope” value as ‘0:x’ where x is any number, according to the desired profile of the roof. Add other relevant values as required.
Place the roof using the ‘Place by: Shape’ option.
