| | Product(s): | OpenBuildings Designer | |
| | Version(s): | CONNECT Edition | |
| | Area: | Import/Export | |
Problem Description
How to convert the referenced DGN file into DWG format in OpenBuildings Designer?
- After opening the container file which contains the reference files go to File > Export > Common File Types > DWG and the export file dialog box will pop up. Then click on Options to select the settings for DWG export.
- After opening the DWG export settings go to References tab and choose the below options as shown in the screengrab below and export the files.
- Finally, after exporting the file we can see that the reference files got exported to DWG format as well.
