| Product(s): | OpenBuildings Designer |
| Area: | Basic Settings with ProjectWise |
| Original Author: | Shreya Basu, Bentley Technical Support Group |
Background:
To optimize ProjectWise and the performance of the local computer it is best practice to clean local documents and workspace biweekly as below, A weekly clean is suggested for heavily used machines, such as CAD drafting.
All files must be saved and checked in first!
Answer:
- Open ProjectWise Explorer>Tools>Local Document Organizer.
- In the Organizer dialog, click the Copies icon and you will see all copies on your machine.
- Select all copies (CTRL + A) or the ones you need to purge, click Purge Copy or right-click the list of files. This will delete local document copies.
- In the Organizer dialog, click the Workspace Copies icon, and you will see all workspace copies on your machine.
- Select all copies (CTRL + A) or the ones you need to purge, click Purge Copy, or right-click the list of files. This will delete local document copies.
