| Product(s): | OpenBuildings Energy Simulator | ||
| Area: | Building Modelling |
Building models in GBXML format can easily be imported directly into OpenBuildings Energy Simulator.
Before proceeding to export your GBXML from your BIM software, please ensure that it has been set up in a manner that can be understood from an energy model perspective - for example each room must be defined as a space, and surrounded on all sides by surfaces; e.g., walls, windows, floor, roofs/ceilings.
Only then will it be interpreted appropriately upon import - please note that achieving this is often an iterative process.
This will complete the import and you can now begin working with your energy model.
