| Product(s): | OpenBuildings Energy Simulator | ||
| Area: | Building Modelling |
The orientation in OpenBuildings Energy Simulator is defined as the angle to your North point from the y axis.
To change your buildings orientation right click on Building in the project tree and select Properties.
Scroll down to Dimensions and edit Orientation as required.
Note that a north arrow can be seen on the floor plan at all times helping with the orientation of the building:
