| Product(s): | OpenPlant Isometrics Manager |
| Version(s): | CONNECT Edition (10.09.00.74 Update 9) |
| Environment: | Windows 10 (64 bit) |
| Area: | Errors & Messages |
| Subarea: | - |
| Original Author: | Frank Pluim, Bentley Product Advantage Group |
In OpenPlant Isometrics Manager, for CONNECT Edition version while creating a new 3 port component, say return Tee custom component, it returns to below error
“Error[0]: SYS mismatch CP/CP count: component ID = 3”
Creating isometric: C:\ProgramData\Bentley\OpenPlant CONNECT Edition_u8\Configuration\WorkSpaces\WorkSpace\WorkSets\OpenPlantMetric\WorkFiles\Isometrics\Styles\IFC\dgn\1-2-4-PSDS_cell-iso-1.dgn
Failed to generate isometrics
Error:Error[0]: SYS mismatch CP/CP count: component ID = 3
в Bentley.Isometrics.IsoExtWrapper.GenerateIsometrics.Execute()
в Bentley.Isometrics.IsoProduction.PipeGenerateIso.Process(IsometricInstance isoInst)
в Bentley.Isometrics.IsoProduction.ProcessingPipes.ProcessIsoInstance(BackgroundWorker bWorker, IsometricInstance isoInst, Boolean& success)
Below steps illustrate on how to resolve below errors while creating new symbol and defining the same in relevant style files.
# RULE gives the classes for which this script is used
RULE: this.GetClass().Name = EQUAL_PIPE_TEE_CELL_FREE_PORT,EQUAL_PIPE_TEE_CELL_FREE_PORT_Z45
# L1 is the effective length of the branch leg. This is normally available via
# DESIGN_LENGTH_CENTER_TO_BRANCH but in your particular case the values are not correct.
# If the component is spec driven the value should be 115 for this component. For now I
# hardcoded it to 115
# L1 = this.DESIGN_LENGTH_CENTER_TO_BRANCH_END_EFFECTIVE
L1 = 115
# The following are basically vector expressions
# A1 is vector in the branch direction with the length of the branch leg
A1 = scale (V3, L1)
# When we subtract this vector from the branch port we get IP3
IP3 = Subtract (P3, A1)
# Calculate the point in the middle between port 1 and 2
A2 = Add (P2, P1)
A2 = Scale (A2, 0.5)
# The vector from that mid-point to IP3
A2 = Subtract (IP3, A2)
# Which can be used to calculate IP1, IP2 relative to P1 and P2
IP1 = Add (P1, A2)
IP2 = Add (P2, A2)
Explaining the match-stick model to OPIM
the SCALER line in the supplemental isometrics schema (for you RETURN_BO) specifies the scalertype. In symbolsizes.def the DEF entry for the scalertype links to an abstract scalertype (here also RETURN_BO)
DEF RETURN_BO RETURN_BO -> DEF <abstract scalertype> <scalertype>
The abstract scalertype is found in the same file in a SYS statement. This is more or less a list of how the match sticks connect to the points (port, IP).
For OpenPlant Isometrics Manager, we number the points from 1 to 6 in the following order P1, P2, P3, IP1, IP2, IP3
SYS RETURN_BO 3 3 5 # 3 CP, 3 IP, 5 segments (pipe return bottom/side outlet)
SEGMENT 1 4 # segment from P1 to IP1
SEGMENT 2 5 # segment from P2 to IP2
SEGMENT 3 6 # segment from P3 to IP3
SEGMENT 4 6 # segment from IP1 to IP3
SEGMENT 5 6 # segment from IP2 to IP3
The SEGLEN part of the DEF entry specifies how long each matchstick will be in the isometric, so 20 for the first segment, 20 for the second etc
SEGLEN 20 20 5 15 15
Till here no cell is created. However, it will generate iso with missed cell but will give direction if correct cell sketched out. See image below:
The isometrics are however generated, but the cells are generated in skeleton style
At the time of creating cells.
It currently is a requirement that the leg length in the cell have the same aspect ratio as what is in the DEF statement. Below an example with a different SEGLEN statement
SEGLEN 8 8 20 30 15
If above problem still persist, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
