| Product(s): | OpenPlant Isometrics Manager |
| Version(s): |
CONNECT Edition 10.09.00.74 (Update 9)
| Environment: | Windows 8.1/10 (64-bit) |
| Area: | BOM |
| Subarea: | BOM report customization |
| Original Author: | Shubham Sawant, Bentley Product Advantage Group |
While generating isometric, the requirement is to combine the whole BOM with desired sequence of the components. Currently, Isometric BOM is created on the basis of Shop Material & Field Material. Now, if one can need to combine all the report without showing Shop & Field section, that can be also possible. Let's say, user needs a BOM in the sequence/pattern as shown
By default, isometrics manager gives the report as shown
In this wiki article, we will see how to combine the BOM & set the sequence as follows.
- Launch OpenPlant Modeler.
- Create a pipeline & place the desired arrangement.
- Generate the isometric with any desired style. Please follow the attached wiki article for how to generate iso
WIKI >> how-to-generate-isometric-insession-outsession-in-connect-edition
- From IsoProcessor dialogue > click on Style configuration > select the desired style & click on Report Defiantion file as shown
Note : one can manually access this file from the location C:\ProgramData\Bentley\OpenPlant CONNECT Edition\Configuration\Workspaces\123\WorkSets\1234\Standards\OpenPlant\Isometrics\styles\IFC\config
- Comment out few lines with "#" as shown. User needs to just add # sign.
- From the Isoprocessor dialogue shown in step-4, click on Style configuration Root as shown
- Open the Rep_sortgroup file.
- Now, set the sequence as shown
- Further Fittings also can be set in sequence if scrolled to the bottom of the same file as shown
Note: One can set this sequence as well for the fittings group. For the moment Reducer > Flange > Elbow is our sequence.
- Save all the files & regenerate the isometric & verify the results as shown
Notice that, the sequence is achieved as mentioned in Image-1 in description.
Note that, some issues is faced due to the sequence of the Supports in BOM. Please refer the below wiki article to resolve that problem
Wiki >> how-to-set-supports-at-last-in-sequence-in-bom-of-isometric
communities.bentley.com/.../how-to-disable-the-terminator-on-leader-line-in-isometrics-via-openplant-isometric-manager
Still a Problem?
If above problem still persists, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround
