Reports - Output Manager - BRCM CONNECT Edition
If you have completed the drafting part of the project and now interested to know the list of quantities & types of all material like raceway, fittings, cable lengths etc. required for the project's execution. You will need to generate reports with accurate data and that can be easily done with Bentley Raceway and Cable Management's Output Manager. The Output Manager enables you to create output from selected design files and cable data.
You can follow the below given articles to learn more about the report generation and customization:
 Index
  1. How to Insert Page Break in BRCM report templates.
  2. How to Utilize Equipment UDAs in BOQ report for Product Codes and Descriptions.
  3. How to Include Raceway Accessories in the BOQ Report
  4. How to add Calculated Fields in Reports.
  5. Functions and Operators list for Report Designer in Bentley Raceway and Cable Management.
  6. How to add the User Defined Attributes into Reports
  7. How to generate Isometric Cable Report
  8. How to apply filters to the Column of the Output Reports.
  9. How to Configure Equipment Product Codes.
  10. How to generate Isometric Cable Report.
  11. How to perform Calculations Product Codes (PCode) Values.
  12. How to Export Custom Cable UDAs in Cable Route List report.
  13. How to Add Equipment UDAs in BOQ Reports.
 External Links
Check Video Content - Bentley raceway and Cable management Tech Tips
Bentley Sign In
learn.bentley.com
Access your Bentley Services
 Comments or Corrections
Bentley's Product Advantage Group requests that you please confine any comments you have on the Wiki entries to this "Comments or Corrections?" section. THANK YOU!
