| Applies To; | |
| Product(s): | AutoPLANT Modeler V8i /CONNECT Object Enabler |
| Version(s): | SS6 (08.11.11.135) | SS7 (08.11.12.226) | SS8 (08.11.13.129/211/08.11.14.01) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | AutoPLANT Modeler CONNECT Edition[FAQ] |
| Subarea: | AutoPLANT Modeler V8i/CONNECT Object Enabler for AutoCAD |
| Original Author: | Kestutis Mitkus, Bentley Product Advantage Group |
AutoPLANT Object Enabler is an AutoCAD plug-in that allows users who do not have AutoPLANT installed to view AutoPLANT objects in AutoCAD.
All AutoPLANT Object Enablers can be found in Bentley Software Fulfilment center.
But there are some situations when users don't have any Bentley software, its support or possibility to download it from Bentley Software fulfilment center and have the need very regularly to interface with drawings/models, that are created using the Bentley software.
In order to help all our users, download AutoPLANT Object Enablers for required AutoPLANT version, we have created this wiki article with Links without expiration date:
Important Note: It is advisable to remove the previous installer and then do fresh installation to avoid any further problem. Also Keep one installer at a time in a machine.
If there is requirement for earlier AutoPLANT Object Enabler versions, please post it in "Comments or Corrections?" section and we will update this wiki with additional link to download it.
communities.bentley.com/.../bentley-autoplant
communities.bentley.com/.../autoplant-modeler-faq
