| Area: | Architectural Design | ||
| Subarea: | Stairs |
Problem Description
How can I calculate concrete volume for stairs?
Steps to Resolve
At the moment, in OpenBuildings Designer you can use one of the two ways to get the volume of the stairs.
1) Use the Building Element Info. Expand the list of Stair and Flight on the right side and then select Free Forma. Go to the Quantities tab and noticed that the Volumes was displaying in the window.
2) Use the Measure Volume tool and select the element you want to measure.
