| Area: | General |
Problem Description
How to eliminate the UnifiedFilenaming Utility error when it pops up while starting the OpenBuildings Designer Please refer to the screengrab below.
When this error pops up while starting your OBD then please go to this location and then remove/rename your “Prefs” folder and then restart your OpenBuildings Designer. Please refer to the screengrab below.
After that you will notice that this error has been removed and OBD is opening smoothly.
