| Area: | Print/Plot |
Problem:
How are levels (layers) included in a PDF created with OpenBuildings printing?
Enable “Optional Content” in the pdf.pltcfg Printer Driver Configuration file. Using the Print Dialog select File > Edit Printer Driver Configuration. After setting “Enable Optional Content” to “On”, save the changes and reload the Printer Driver Configuration under the File menu in the Print Dialog.
