| Area: | General |
When opening a DGN file, I am sometimes facing this "DTD/Schema" error message:
First, go to the ‘Schema Upgrade Utility’ which you can find under this path: File>Utilities>Data Utilities> Schema Upgrade Utility
Then when this window pops up click on the Upgrade button:
After doing so the DTD/Schema error should no longer display.
