| Product: | OpenBuildings Designer | ||
| Versions: | CONNECT | ||
| Area: | Levels | ||
| Subarea: | General |
How to turn on or off the View Display of levels with a key-in?
The "set levels on/off" key-in allows user to turn off the View Display of any level by name/number specification.
The syntax according to current MicroStation documentation is as follows:
Key-in:
For example, to turn off level number 1, the key-in sytax would be: set levels off 1
Similarly, if you had a level name, say "Curb_Gutter", then the key-in syntax for the same thing would be: set levels off Curb_Gutter
To turn on/off all levels in the DGN (with exception to the current active level) through key-in type: set levels on/off all
Note that for these key-ins, you will be prompted to select the desired view to turn on/off levels in.
If you wish to implement this key-in within a batch routine, you can use the following syntax:
set levels on/off all; selview 1
This will turn off all levels in view 1.
