| Product(s): | OpenBuildings Designer | |
| Version(s): | CONNECT Edition | |
| Area: | General | |
Background:
You can use the Remap Elements tool to change elements from their current level (or levels) to a different level(s).
Steps to Accomplish:
Below is the workflow to change the level of elements to different level:
- Hover over the elements to be modified, for example, Duct. In this case, you can see the level of the duct is "M-EF-65-40-M-Ventilation" using the flyover, or you can see the same in the Building Elements Info dialog.
- Next, choose Level Manager under the Common Tools group, right-click on the original source level, and select Remap Elements.
- Select the Destination level name that will be mapped to the source level and then click OK. Now the destination level (A_CA_70_10_10-M_SiteAccommodation) has been applied to the Duct.
