| ID | Title |
| 672788 | Resolved issues with Enegry Simulator dry & wet bulb Maximum & Minimum temperatures are not matching with Hevacomp in CIBSE Maxi gain, AirFlow & Summer temperature calculations on design data tab. |
| 672814 | Resolved issues with Enegry Simulator add room schedule option and TM52 calculations in Simulation Frequency calculations. |
| 692529 | Resolved side-by-side installation of OpenBuildings Designer |
| 695420 | Resolved issues with ECS axes remained at its place after mirroring the steel element. |
| 790399 | Fixed issues related to OpenBuildings Energy Simulator - menu loading times. |
| 803642 | Fixed RFA import wizard issue which was not showing some options when tried to add items from Component center. |
| 814611 | Resolved issues with Energy Simulator HVAC Manager Plant data fuel type errors |
| 826371 | Fixed missing delta_guide for dataset DE (OBD_Dataset_Delta_Guide_U8-U9.pdf) in following Datasets |
| 853569 | Resolved issues with exporting the ProStructure elements to CIS/2 file format has missing Linear_Member_Type |
| 901642 | Resolved issues on OpenBuildings Designer stuck when using ‘Capture Google Earth Image’ tool. |
| 901662 | Resolved Compound Part mapping utility issue in dataset SG which was crashing when trying to convert Aircon.cel |
| 901724 | Fixed workflow issues from AECOsim (DGN) to Navisworks (NWC) |
| 901725 | Resolved issues with Importing/Copying "saved View" from one model to another does not copy the links to the drawings and reference. See details. |
| 934858 | Resolved issues with Energy Simulator Weather Data Longitude Coordinates |
| 989022 | Fixed crash during modification in Reference presentation in Drawing is causing OBD to crash. |
| 999499 | Resolved issues with cannot hide the ribbon bar Search field. |
| 1070438 | Resolved issues with archWindow in catalog editor does not have Cell as File type. |
| 1076230 | Resolved issues with wrong SaveAs Options while saving as DWG format. |
| 1084176 | Resolved issues with hidden Lines not following ST Rules unless Symbology is set to ByLevel |
| 1086407 | Fixed issues related to IFC (2x3) files containing revolving solid are not getting opened/referenced |
| 1098662 | Fixed issues related to ProjectWise where exporting schedule to excel with a custom template is getting saved in the DMS folder which should be inside PW |
| 1104475 | Resolved issues with CVE Tolerance value is high |
| 1178321 | Fixed OBD crash when visible edge is set to Cached Automatic |
| 1223537 | Fixed OpenBuildings crashes on Export with Display Rules |
| 1235092 | Fixed dataset issues on Material Definition missing |
| 1241092 | Fixed OBD crashes when opening an IFC file |
| 1276829 | Resolved issues with windows and curtain wall can't be displayed rendering materials. |
