| Product(s): | OpenBuildings Designer | |
| Version(s): | CONNECT Edition | |
| Area: | ProjectWise Integration | |
Problem description
How do I enable ProjectWise desktop integration with OpenBuildings Designer?
Below is the workflow that will allow you to enable ProjectWise Desktop integration with OpenBuildings Designer.
- Open the BuildingDesigner_PW.cfg file from this location: C:\Program Files\Bentley\OpenBuildings CONNECT Edition\OpenBuildingsDesigner\Config\appl\
- Add a # in front of the variable PW_DISABLE_INTEGRATION_FROM_DESKTOP:1. This will "comment out" the variable to enable ProjectWise integration when OpenBuildings Designer is launched from the desktop.
- Next, use the ProjectWise Log in dialog box to log in to your ProjectWise Datasource from OpenBuildings Designer, after which you will get the ProjectWise datasource browser.
