| Area: | Platform Tools | ||
| Subarea: | Line Styles |
Problem description:
How do I set the Active Global Line Style Scale Factor for custom line styles?
Below is the workflow that needs to be followed to change the Active Global Line Style Scale Factor for custom line styles:
GLOBALLY
- Key-in: ACTIVE LINESTYLESCALE [value]
AT THE ELEMENT (New elements)
- Open the Custom Linestyle dialog by choosing Settings > Linestyles > Custom
- Enable and set "Scale Factor"
AT THE ELEMENT (Existing elements)
- Key-in: CHANGE LINESTYLESCALE [value]
- Select element(s)
