| Area: | Structural Design |
Problem Description
When selecting the User Shape Manager nothing pops up and it is not opening. How to resolve it?
In this case please rename/remove your “Prefs” folder from this location: C:\Users\User_Name\AppData\Local\Bentley\OpenBuildingsDesigner and then restart OpenBuildings Designer. Please refer to the image below.
Finally, after clearing the Prefs folder you should see that you are now able to access the User Shape Manager in OpenBuildings Designer.
