| Product(s): | OpenPlant PID CONNECT Edition |
| Version(s): |
10.07.00.32 Update 7 |
| Environment: | Windows 7/8.1/10 (64-bit) |
| Area: | Customization |
| Subarea: | User Interface |
| Original Author: | Abhijit Bute, Bentley Product Advantage Group |
User wants to create new pipeline with Specific line styles, following illustrative steps helps to create new Pipeline with desired linestyle
Add New Level for new PipeLine
Add New Template Group
3. Open Element Template, make Sure Workflow should be Home > Collections > Element Template.
4. Add New Template and give name BentLine1 under Pipeline
Customize Ribbon and Add New PipeLine
5, Go to File >Settings > Customize Ribbon.
6. Go to OpenPlantPID > PID Gallery Components > Piping
Right click Add New Button
Use Key-in pid insert OpenPlant_PID BentLine1
7. Click Apply.
Add new Pipeline Entry in schema.
8. Open Bentley Class Editor and Open 01.08.ecschema.xml. And supplement with OpenPlant_PID_Supplemental_Design.01.08.ecschema.xm
Located on WorkSet location
For ex: C:\ProgramData\Bentley\OpenPlant CONNECT Edition\Configuration\Workspaces\OpenPlantExample\WorkSets\METRIC\Standards\OpenPlant\Schemas
9. Search for Pipeline class.
10. Add derived class and give class name BENTLINE1.
11. Add Custom Attribute Schematic CAD Custom Attributes & Jumper mapping.
12. Add Entry as per below screenshot.
13.Under Pipeline List class add new Pipeline entry.
14. Save the Schema.
15. Open Any OpenPlant PID model. Open Element Template and select option Update Template from Library.
16. Place Pipeline BentlLine1.
communities.bentley.com/.../how-to-create-multi-line-style-pipeline-with-different-line-weights
If above problem still persists, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround
