| Product(s): | AECOsim Building Designer | |
| Version(s): | V8i | |
| Area: | HVAC Design | |
Problem Description
How to change the name of the Properties under the Parameter section while placing any mechanical elements as shown in the image below?
Please refer to the steps below to achieve this:
- First, open the Definition Editor and under Properties definition when you hover over the Status definition it will give you the path to the XML file as shown in the image below.
- Next, navigate to the location “C:\ProgramData\Bentley\AECOsimBuildingDesigner V8i Ss6\WorkSpace\BuildingDatasets\Dataset_US\datagroupsystem” as shown in the Definition Editor and open the “xml” file to rename the property as per our requirement (in this case Status was used).
- After renaming the property, remove the “Prefs” folder from this location: C:\Users\User_Name\AppData\Local\Bentley\AECOsimBuildingDesigner and restart AECOsim Building Designer.
- Upon restarting you should see that while placing any mechanical element (in this case Duct was used) the Properties are renamed as per your requirement, and in the Schedule, you can see that updated name will be reflected. Please refer to the images below.
