| Product(s): | OpenPlant Modeler CONNECT Edition |
| Version(s): |
10.04.00.30+
| Environment: | Windows 7/8.1/10 (64-bit) |
| Area: | Customization |
| Subarea: | Pipeline |
| Original Author: | Deepak Singh,Bentley Product Advantage Group |
In OpenPlant Modeler CONNECT Edition, requirement is to add dimensional unit to added or existing property in OpenPlant Modeler CONNECT Edition.
In OpenPlant Modeler CONNECT Edition, for a custom added property user can add its dimensional unit using OpenPlant Project Administrator CONNECT Edition. Below wiki article explain the procedure to achieve this requirement.
- Launch OpenPlant Project Administrator CONNECT Edition.
- Select your desired workset, here OpenPlant Metric is considered.
- Expand the workset node & select your desired product icon. Refer image below.
- From Ribbon interface, select Settings and click on Schema Editor as shown below.
- This will evoke Schema Configuration window
- Enter desired class name, here Pipeline class to Search box & click on Search icon. Refer image below.
- Expand the Classes node & select Pipeline class as shown below.
- Select Properties tab & click on “+” icon to add a new property as shown below.
- To Add New Property dialog, enter desired property name that needs to be added.
- Click on Display label field, notice that it automatically updates the display label to lower case & remove the underscore as shown below.
- Change the Type to Double.
- For Kind of quantity select desired quantity from list. In this article Volume Flow Rate is taken as an example. Refer image below.
- Select desired Unit from list as shown below.
- Click on OK.
- Click on Save to save all the changes. Refer image below.
- Launch OpenPlant Modeler CONNECT Edition, create a pipeline & verify the customization.
Still a Problem?
If above problem still persists, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
