| Area: | Datasets and Content | ||
| Subarea: |
We currently deliver the following regional datasets with OpenBuildings Designer:
Regional datasets are selected during product installation. Datasets can be added or removed using the Modify option via the Windows Apps and Features settings dialog.
The default location for OpenBuildings Designer datasets is "C:\ProgramData\Bentley\OpenBuildings CONNECT Edition\Configuration\Datasets".
