| Version(s): | V8i SELECTseries 6 | ||
| Area: | Import/Export | ||
| Subarea: | IFC |
When exporting a file to IFC, the IFC Export dialog with mapping options for Map DataGroup Types and Properties displays the IFC Mapping items in red.
Check whether the following file exists - C:\ProgramData\Bentley\AECOsimBuildingDesigner V8i Ss6\WorkSpace\BuildingDatasets\Dataset_US\data\classifications\IFC_2x3_Entities.xml
Go to C:\ProgramData\Bentley\AECOsimBuildingDesigner V8i Ss6\WorkSpace\BuildingDatasets\Dataset_US\data\classifications\IFC_2x3_Entities.xml or to the location of your dataset data\classification\ folder to be sure that the file IFC_2x3_Entities.xml exists in it.
