| Area: | Platform Tools | ||
| Subarea: | References |
How can I control the display of nested reference attachments? If I turn off the display of the direct attachment all of the nested references are also turned off.
1. Open the 'References' dialog and click on the "Show Hierarchy" button.
2. Once the Hierarchy window opens on the left-hand side you can expand the tree view of reference attachments.
3. Select the reference attachment that includes the desired nested attachment, and on the right side turn off its display.
