OBD Crashes when Opening Deck Tool
  Product(s): OpenBuildings Designer
  Version(s): Connect Edition & 2023
  Area: Structural Design
  Subarea: Deck
OBD crashes when opening Deck Tool with Exception code 0xe0434352.
In Services, confirm that Bentley Property Catalog Service status is running. If stopped, start the service then relaunch OBD.
If the Bentley Property Catalog Service is missing, check in Programs and Features whether you have Itwin Analytical Synchronizer installed. If not, download the app from this link. After installation, reboot your machine and confirm in Services whether the Bentley Property Catalog Service is running.
