OpenBuildings ProjectWise Compatibility
(30885 False)
  Product(s): OpenBuildings Designer
OpenBuildings Station Designer
  Version(s): 10.xx.xx.xxx, 2023, 2024
  Area: ProjectWise Integration
  Subarea: ProjectWise Compatibility
ProjectWise Compatibility with OpenBuildings Designer and OpenBuildings Station Designer
Following are the compatibilities across different released versions of OpenBuildings Designer and OpenBuildings Station Designer with ProjectWise. The compatibility matrix is available in PDF format and can be downloaded below:
https://bentleysystems.service-now.com/community?id=community_document&sys_id=ce76ec4887b12610e25dbb35dabb35a2
See Also:
ProjectWise Version Support Matrix - Operating system (Windows), SQL Server/Oracle database, third-party and Bentley application compatibility matrix for ProjectWise CONNECT Edition and 2023 releases.
The Product Readme files for specific versions of OpenBuildings are available here.
